I am an amateur sound guy operating the QU16 for my band and at some rock gigs.
Previously, on older and cheaper analogue desks I had been able to mute a channel which resulted in no sound from FOH but as it was pre-fader, and the aux send was turned up, it was still audible in the monitors.
Is there a way to achieve this on the QU? I like to run slick change-overs and this would really help me.
I can PFL and ear it myself but often it’ll set the musicians at rest if they’ve heard it for themselves.
You could simply use the Mute button on the master fader to simply kill the sound to FOH only. Of course, the monitors will be live so watch out for folks unplugging instruments, etc.
Thank you for your reply, Jline. This is not an option though as I’d want to be playing music between bands.
My plan to overcome the popping and over zealous lea pluger-inners was to unassigned the channels whilst changing/plugging in and then reassign, channel by channel, as I checked each instrument in. The audience hear the cd and the rest of us can hear what we need to.
An easy way would be to assign all but your cd to a mute group which you could enable/disable as you plug/unplug your channels from your iPad on stage? I don’t have my desk to hand to see if hitting the mute button on a channel selected in a mute group defeats the mute. That would be easier again but I can’t recall if it works that way…!
I currently have all mics in a mute group and actually do what you suggest. It works well. Problem is that once the physical plugging has been done I want to line check equipment without it coming over the FOH but I want it to hit the performer in the Monitors. At present the Mute overrides all mix outs.
I’m thinking though, the best thing might be to unassign mics/DIs/laptop inputs from main mix and then un-muting channels will result in sound in monitors but not FOH.
You can remove the channel-assign to the MAIN LR on the channels that you want to line check! Just hold down the ASSIGN button and press the select button of the specific input-channel to remove it from LR but still to pass audio trough the monitors! Maybe you could set up a scene where everything is “safe” except the assignment! (i think it’s not possible at the moment…) Another suggestion is to move all Input-Fader on the MAIN-Mix to infinity! (Maybe you could safe that in a scene?)
This seems like the easiest way to accomplish your goal, and it is quick to un-assign/assign channels as needed by holding the Assign button and selecting the necessary channels.
