Mute safe quick assignment
it sometimes happens that you have for example all vocal mics muted by group and then suddenly someone appears on stage to do any kind of announcement whatever. When working with analog consoles, there was a mute safe option to every channel to override the mute group. Is there a possibility to add a toggle fuction, my suggestion would be to hold “reset” and press mute on the corresponding channel to deactivate all mute assignments for this channel and then do the same thing do re-activate these mute assignments? This could be added to all console ranges, as they all have the reset button.
Good call. That has been happening to me a lot lately.
On the Digidesign Profile you could simply hit the mute a couple of times to bypass whatever mute was in place on the channel, be it DCA or (iirc) mute groups.
Would be great if they could implement this on the dLives as well as on SQ.
This is a much requested feature.
I would suggest that you both find the older threads and add your vote to the original requests. Adding another feature request post simply “waters down” the level of interest being shown because it is spread out over many threads that all ask the same thing.
