My Ilive T-112 does not keep the scenes memorized
Hi. When I disconnect my Ilive T-112 for a day and turn it on again, it does not keep its memory the scenes I had memorized. I have to reload the show in full.
I already changed the battery button that is on the computer that governs the screen, but the problem persists.
Anyone else has happened? Do you know the solution? It may be that you have to change another battery?
Greetings and many thanks.
Hello.
Same for me since 1 week
Are these fixed installs with the same mix rack? You aren’t powering up the surface without a mix rack connection are you?
IIRC with the last firmware update the storage location of show files was moved from the surface to the mix racks.
What part of your scenes are missing? Just part of them or the entire scene?
You aren’t trying to recall something that is scene safe?
Hello.
Thank you for your reply.
IDR turned on first, the same scene is charged at each turn on, empty fx rack. The same usb key for 3 months, and backup identical surface.
Sorry for my English, I’m French …
cordially
Have you looked at the scene “edit” window for the scene to verify that the FX rack is part of the scene data saved.
Hello. I will check for the fx rack, but the scene that loads is empty, rack, but also track from 1 to 48.
(the scene when the console is turned on)
Hello. Yesterday, normal loading of the scene when lighting the console …
Several concerts this week, I’ll see.
