Named aux1, aux2 etc in mixpad app
Although the physical desk doesn’t have a right hand side scribble step by each mix select, I can use a physical label for each mix select button to describe which mix is which.
On mixpad however I can’t use a physical label obviously, but the app could easily use the labels given for each mix rather than aux1 etc. At the moment in the app you select the mix, then see it’s name on the master fader making it a guessing game finding the right mix.
  • 1 on this. Seems like an easy software fix.
Sq-mixpad ver1.3 you have center of the screen a button with up and down arrows. Swipe that up to expand the faders which will also give you the pan option, swipe down and you’ll have more options for each parameter you chose, including channel naming and picking the color for each channel.
If you swipe down faders on PEQ screen you can swtch on/off HPF
