Names for Devices - Network settings...
Hi guys, just a qucik warning. Dont evenr have spaces in any of the device names under network settings! this will mean the editor will not connect.
this is a bug i believe as you should not be able to type in characters that will ‘break’ things… if you know what i mean. its just like when naming a PC, windows wont let you use a space, its an illegal charater. ilive software needs to have this feature too!
its not different to pressing a certain key or combination and then having the console crash.
Hi Jeremy
The default iLive device names already have spaces in so i do not think this will be your issue. If you have some more specific info on what characters will lead to editor not connecting and a reproduce procedure please let me know.
What are the names of your devices when Editor will not connect?
Regards
Sam A&H
Ok I’ve done some further investigation…
Spaces are fine, so are dashes. But if I name the surface ‘T112 - 1’, then we get not connection. This across all surfaces and mixracks etc.
Hi Jeremy
Thanks for the info, We are investigating the issue.
Regards
Sam
A&H
