Hello forum,
the names of the groups in the layer are correct but the names in the routing screen are from a another show.
I use a T112
thanks for your time
Hello forum,
I use a T112
what firmware version?
Regards
Lieven
T112/IDR48/R72/IDR16/IPAD
Save a tree, eat a beaver
The firmware is 1.70. I know I need to update but its not my console
Nearly the same here with 1.81.
We shut down the idr Rack for testing the backup situation.
We reconnected the surface, everything was ok but we missed all the channel names in the routing dialog.
Solution:
We renamed just one channel - and all others where renamed also correctly.
ThomasB
idr32 T80
Yes,today working with version 1.8 same problem, after changing just one name in the input strip the problem is solved. Strange…[ ]
so this in one point for 1.82 i think.
IDR 48 T80
I had the same behaviour yesterday with 1.82, but only on one client out of four.
Furthermore, every startup of editor he loses more or less names, and it seems to be that only the first 16 channels are not recognized.
Probably it has something to do with the java version, because the clients run different versions…
Solution with renaming one channel functions except the channel coloring.
Second solution for me was the import of channel names tool (Tool cuts down the names down to five characters).
I will investigate that during the next days:)
idr32
Editor only (3 times)
Korg nano
Dante
Have you checked your scene safes…just a thought…
T112|iDR48+ACEcard|Laptop|iDR16|iPad|iPS10
