Hi guys,
here’s the situation:
I have a wireless access point EnGenius ECB9500 connected via 1 meter long cat5e cable to idr10.
idr10 is using v1.90 firmware.
I am using for OneMix app only. There are 3 ipads connections, and T112 Surface.
Somehow OneMix app lost its connection to the mixrack after every about 15 minutes of idle…
I checked my ipad to wireless access point/ router connection, it was fine.
I put the router & mixrack at the stage, so distance & signal strength are not the issues.
I had to close the app and re-open to get it to work again. I set the auto-lock to ‘Never’
IP address of mixrack, surface, touchscreen are default settings.
wireless AP is 192.168.1.254
DHCP range is 192.168.1.100 - 192.168.1.200
Please help
Is your DHCP set to renew lease every 15 min?
Gil Parente
Design & Integration
Entertainment Arts, Inc.
iLive 176, T112
iDR48 , iDR16, iDR10
Multiple iPads
Dante
Etc…
I’ll check later today, but I remember I set the channel selection to ‘auto’ with
half an hour period of changing → the router will look for the clearest channel every half an hour and change into that channel.
Does this also affect the stability besides the DHCP lease time?
quote:
Gil Parente
iLive 176, T112
Multiple iPads
Dante
Etc…
Hi all
I checked. DHCP lease time is set to ‘forever’.
However I did several things:
Disable CTS Protection on router
Upgrade iLive firmware to v1.91.
Everything works flawlessly now. No drop outs.
However, the metering didn’t work in OneMix.
Pls help (again)
Thx
