It seems like my SQ6 cannot connect to the network. The link light starts blinking every ~3 seconds, and eventually it will stop. The link LED on the switch it is connected to doesn’t light up. Does work perfectly with the same conditions on v1.4.
There were some changes to the network connectivity in V1.5, in that we added the auto address function which kicks in if an address is not assigned via DHCP.
However, I’m not sure how this might affect you without knowing the full details of the setup.
Please contact us using support.allen-heath.com with info on the connections, network, router/access point and how you have everything configured so we can figure this out with you.
