Running Firmware 1.4.1r3454 on my SQ5.
Tried to set a static IP address on the mixer.
Failed, because it is not possible to change the subnet mask although there is a stencil icon beneath.
I can’t be sure now but I seem to recall a fix for that being in the quickly removed 1.4.2 update, so once they resolve the problem that led to that being taken down you might be OK. (I had to revert to 1.4.1 myself because I was hit by the apparently obscure problem).
Hi Edi,
As Peter says, this is a known issue that snuck into V1.4.1 and will be addressed in the next update.
It is possible to roll back the fw version, make a change and then update again, which whilst not ideal, could be used if needed.
Our apologies!
Cheers,
