Networking question
I have a iLive T112 with a iDR10 connected with ACE and port B outputting ES to the mains, I need to some how add a monitor console, for that I have a T80 and iDR-64. (I also have a spare iDR-64). Any ideas on how to do this dig?
Well send me your spare 64 :stuck_out_tongue:
But in all seriousness, need a few questions answered first
A: are you using an analogue split, or do you want the monitor console to copy from your idr10? I assume you are wanting a split from your idr10 otherwise there would be absolutely no reason to network em.
So, The remote audio card has two ace ports, I believe you can just run from that second ace port directly to your monitor console. But I assume you are wanting the additional dsp power? That’s what the idr0 is made for, but as you have an idr64 you can use that instead. Am I right n assuming all you will be using is its outputs?
https://www.allen-heath.com/UK/Products/Pages/iLiveTrainingVideos.aspx?TOV=1&CatId=iLiveSeries&SID=36
Tim Tyler
Detonator Sound
Richmond, Va USA
T112/48 R72/32 laptop iPad Dir-815 Dante
