New feature: eartraining
Hey - today I discovered a new feature on SQ-Series: free Eartraining!
Instead to the deep processing plugins - This is for FREE!!!
I used the desk today at a live show without router - and so without any remote.
Then: display freeze! Yeah - thanks A&H!
Rest of the show doing processing without any visual feedback! That’s Audio engineering at its best.
But as feature request:
Please A&H install a Button to exit the screen freeze! Because for some Parameters the display would be helpful…
Yours dd
Hi!
I’m sorry to hear you’re having trouble with your SQ.
This sounds like a known issue in the latest firmware version and our developers are working on a fix for this at the moment.
It’s caused by using both the RTA on PEQ and the SQ-Drive at the same time, so if you stop using one of these it will avoid the freeze until new firmware is available.
If you do experience the freeze again, this affects the video of the screen only and all control is still operational. You could connect an instance of SQ-MixPad as well so you can finish the show.
Alex
Hi Alex,
Thanks for the answer + temprarily solution!
greetings
