Hello, I’m having an issue using Daw control with my QU 32 in both Ableton live 10 and Logic Pro. I’ve followed the instructions regarding downloading the latest Daw Control software, everything is setup as recommended as far as using Mackie control, Daw control 1, 2, 3, and 4. When I move fader 1 it moves faders 9, 17, 25 as well. Fader 2 moves fader 10, 18, and 26 and so on. It does this in both Daws exactly the same. Each bank of 8 is grouped together no matter what settings I try. Has anyone else encountered this issue? Thanks
Forgot to mention
Mac Catalina 10.15.7
Qu 32 1.95 firmware
Ableton live 10.1.30
Logic Pro 10.6.1
Hi Mrauto,
did you solve the problem?
I have the same issue.
Greetings,
Wout
Been a while but revisiting this, did you get it sorted.
I’ve just had the same problem using QU-16 and Logic. After several hours, found a comment in a YouTube video offering the solution.
For each daw controller, set the Fader bank offset for each controller.
Controller 1 = 0
Controller 2 = 8
Controller 3 = 16
Controller 4 = 24
Coloured bars under each track in mixer view represent the colour assigned to the daw controller.
