I have been searching for documentation for possible upgrades that would allow this but not having any luck. Idea set up would include I-live modular surface for FOH- Idr64 also FOH and inputs, Rab 2 mod with Ace to link surface to IDR-64- Ace split to IDR48 linked to R-72 for control of monitors. TRICKY part[:o)] is to get full use of Dante for recording purposes. Originally was told and understood possibility of using a second rab2 module at the surface. My conclusion is that this is not possible.[ ] unless there is an update that I can’t find that would allow that, or the m-Dante to be inserted into the Port B of Rab2 mod at surface. Seems that having only the slot b otion on the IDR limits this a bit. Any suggestions appreciated.[8] on this one
This had been my back up if there is no other. I had the hopes of being able to keep it as easy as possible. Sounds like this may be the best option. Thanks for the Input. Sam, Thanks for the hard work you guys do in monitoring and updating here on the forum.
