Something is setup improperly. Check all of the FX units and remove any outputs to monitors, and mute them all initially for testing. Next check the delay settings on the AUX busses which are being used as monitors and set them to 0ms. Check the individual channel delays too and set them to 0ms.
Once the FX are disabled and the delays are all at 0ms, see if you still get an echo. If so the cause may be outside of the GLD system.
It’s been awhile since I’ve done this on a GLD but I think…press the Mix buttons to select the Aux that the monitors are on. Maybe on layer B on right side. Then go to layer C I think and see if the FX returns are up. If they are pull them down. That should kill the reverb returns to the Aux mix. Do the same for other Aux mixes.
Be sure to save that scene to retain those changes.
