Hi - first post here- new to QU32 which is USB streaming to and from Pro Tools9 (Win7) -
question: Outputs in DAW (1-32) must route to an input on the QU or ? How can i send directly to the Mix-4 +5-6’s on the back of the QU? I want to send 6 aux’s to my Furman headphone system? Must i use 6 inputs on the QU and then route them to the individual MIX outputs?
thank you!
yes
this is not an audio interface as you think, it is a mixing desk in the first place
If you record some tracks you can handle your monitoring completely with the QU32
you can set your headphone mixes with low latency outside of PT and with fader control on a physical surface
Thank you SteffenR
you are correct, i am coming from an interface / front-end mixer to the Qu32 and i understand that my workflow will change.
Without diving into the deep-end and learning the DAW Controller program (custom strip / midi / HUI interface) , i hoped to try and pick up where i left off - for the sake of current projects and legacy sessions.
new questions - if fully integrating the board with the DAW - where is my output? how do i finish a mix? USB-A to a external drive? or bounce-to-disk in the box, as i have previously done?
or do i route my Master L-R from the board back to the DAW and Bounce-to-disk?
i think i fully understand all options but nothing ‘in practice’ yet…
thank you!
I’m afraid I have no real answer to your new question, since all your ideas are possible
right, thank you! very helpful!
ok - more q’s…I also have a AB168 which i have not yet connected. My thought was 16 local inputs and 16 Dsnake - on the QU32 - 32x32 in and out of Pro Tools via USB-streaming
My question is - the remaining 17-32 Local channels ? they no longer exists since i must choose between local and DSnake - correct?
they still exist but are not patched to a channel strip
you can save setups in scenes and switch between the possible situations
the use of recall filters enables you to limit changes to patching only
you can leave your devices or microphones plugged and can switch the sockets
just like on an analog patchbay
yes, ok great examples - thank you
as you might tell, i am fortunate to have scored this great board with the intentions of upgrading my home studio while being shut-down. Many projects ended abruptly a few months ago with full intentions of starting up again with the new hardware.
I could sacrifice 6 more inputs for my headphone feeds and route them to the MIX outs, as i am routing the DAW Mater to Ch31&32 to Master LR and AES.
I could then use the remaining 24 inputs for sources…this is as close to my past workflow and my head is already around it.
But could you help me get my head around your initial suggestion:
i believe this to mean that i USB-B Stream 30 channels in to DAW while i sub MIX out my 6 ‘groups’ from the board to my headphone feeds
Chan 31-32 are my DAW Master returns and this is where the latency will occur?
Is the headphone now tracking to a mix? or how does the headphone continue to receive the 6 individual feeds on playback?
my signal paths are all twisted up in my head, please bare with me?
yes and no…
the playback latency will introduce on this but it doesn’t matter
the point is the desk latency is always the same… it does not change with desk processing attached
take your playback (you can mix it on the master bus of PT to cater the needs of the artist for tracking)
and send it to a stereo channel on QU and add your channels that you will record and the playback to an aux mix
use this aux mix for your headphone amps…
that simple…
an advanced version would be to send an artist mix different then the master…
make shure that you exclude the channels that you actually record from the mix in PT
otherwise feel free to send back to QU all playback signals as single channels and do your monitor mix entirely in QU
including reverbs and FX, it depends on what you like more… totally matter of taste
it is possible to migrate slowly to the new workflow, do one step at a time
thanks again Steffen - let me apply some of this knowledge and report back.
could you just clarify that when you say ‘aux mix’ you are referring to MIX1-4 5-6, etc?
thanks
yes I reffered to the mixes 1-10
a different possibility would be to use ME units to provide monitoring for artists…
yes! thanks, that is the ultimate out-come, budget permitting
