Hi, i recently tried streaming on my MacBook using obs but when i connected everything there was no audio coming through from the mixer, i have used the same setup on windows and it has worked properly with the driver installed, is there anything that i will need to install for it to work or is there something i am just not doing right in the setup of things, any help would be appreciated, it is showing up on OBS but no audio is coming through
Hey Eli,
What mixer are you using?
You’ve posted this in the AHM forum which probably isn’t right for an OBS question as AHM doesn’t have USB.
Hi sorry where should i have posted it?
I am using the Qu 32
Mac normally don’t need the A&H drivers.
In OBS have you selected the Allen Heath as the input audio source?
In the mixer you will need to patch the mix out you want to use for the streaming audio feed to the the USB tracks that OBS is looking for.
Hi, yes i have selected the qu 32 on obs, i am not sure about the patching i do know that mix 5/6 is being sent through the USB though
