No audio QU24
I’m having troubles with my QU24. I’m using the panel in a rehearsal.
All settings are as always. Nothing has changed.
With the startup today, I haven’t any output audio.
I did following:
  • double ckecked my speakers (direct connections work)
  • Replaced All xlr-cables
  • Microphone connected through dsnake. All input source are patched to dsnake.
  • Tried connections with local.
  • PAFL on input shows meter activity
  • PAFL on LR output shows meter activity
  • PAFL on monitor mix shows meter activity
  • Nothing muted
  • I’ve connected a small behringer table on monitor output. This small table doesn’t receive any signal. (Dead meter)
There’s no audio on main speaker, monitor and even no headphone output on table.
In short: all settings seems ok. Anyway no sound.
I’m sure I overlooked something. But I can’t figured out what.
Thanks for helping.
Try loading a default scene and checking basics on that.
Complete output hardware failure on the QU and dSnake is vanishingly unlikely
Resetting the desk from the scenes menu, as Bob says, is a good thing to try.
Are you using the desk or the Dsnake for outputs? If Snake, double check patching.
Connect something (the small Behringer & a mic?) to each of the leads you use to output from the Qu-24/Dsnake in turn and prove everything from there onwards works.
Are your outputs set to be controlled by a DCA? Or Mute Group?
Try all the suggestions that have been made. That said we have seen one QU24 in Dubai that exhibited same problem. Everything appeared to be working except no audio from LR sockets. Had to be replaced. I consulted with that person by email and phone call. Everything pointed to a problem.
Thanks for helping.
Resetted mix settings. Tried local connection again.
Not working. No input signal on local connection.
Tried hard reset of the panel and start over again with factory defaults.
No input on local.
On every input channel the Gain Reduction led is always on. (Is this normal?)
No input anymore now.
I’ve called technical support. Probably system failure. They will fix it.
