No output to front of FOH from channel 3 / St3
This is probably something stupid and a simple fix, but I`m struggling to find it.
I have ST3 playing music (an Mp3 player going in ) and going out great to FOH, when I change to channel strip ( I have a floor tom on that) I get nothing going to FOH I get a great signal from the drum coming in but I cant get anything to go to front of house. Please help!!
Steve
Press the “assign” butoon when on the desired layer/mix/bus and you’ll see the channel lights of the assigned channels light up. Chances are you won’t see the green light for that channel and will merely have to press the channel select button while holding the assign button to get it green-lighted and passing signal to the desired bus.
Yep that was it thank you! I knew it would be something simple. Only had the desk a few days. Thanks again!!!
