I’m not getting out put on my speakers
But I can hear on my headphones
I’m useing powered monitor mixer and peavey vsx 26 to get main out
Need help have a show today
What output plugged in what amp?
Desk setup?
Alt out surface pot turned down?
Need a lot more info…
I’m useing genelic powered monitor I’m not able to get sound from the speaker . I’m useing qu24 desk
maybe you should focus on knitting
what is so difficult to provide more information?
No info, no help…
What more information
If you have sound on your headphones then in theory you should have sound on your main LR output and your Alt out. That is assuming you have properly wired cables. Your alt out has to convert from 1/4" to what your speakers have. Are they balanced or unbalanced. That could be the problem. Check the preferences for Alt out to make sure it’s set for LR output.
It is LR AND IT IS BLANCED
It’s no good saying the same thing three times, we need MORE information - and RTFM.
So you’ve proved you’re incompetent, let’s go back to class.
1 - Are your speakers actually working? Check powering and that you’re in the proper input.
2 - With LR mix selected (above main OP fader - blue light should be on) put Min fader to the 0dB mark and fade up a channel with some audio on it that’s routed to LR OUT.
3 - The bright flashy LED thing that us professionals call “The Meter” should be lighting up green and yellow.
4 - If it’s not, then you are listening to something on your headphones that isn’t on LR Out.
5 - Have you got a PAFL button pressed somewhere? Check ALL THREE layers.
6 - I’d have a good look at the VSX26 speaker processor if I were you - probably not configured properly.
7 - Stop flapping about like a wet hen and follow the signal path PROPERLY through the system, tracking and verifying what works along the pathway.
8 - Don’t blame the kit - most faults can be traced to the idiot who connected it up.
Speakers are working fine on another desk
Blue light is on and fader is also on 0db
There is reading on meter
Ok will check it thank you
make photos of your setup
Photos attached
No photo’s to be seen (over here anyway)
Giga
1st pic
Desk
Images are not getting uploaded
Indeed!
Works for me thought.
This is a gig with QU-16, though not much help in diagnosing your problem!
Go to “Scenes”.
Reset Mix Settings.
Try again.
I did that
Load scene?
Wow - there was some serious flaming on here last year!!
What was the cause in the end? I’m searching for some threads which might help me diagnose a problem with my QU-24 so it’d be useful to see what the issue was.
Robin
