No sound
Hey there! Got a nice deal for a QU Pac for $1300 and ran into my first problem. No sound! I plugged my QSc k.2 series into the mains in the back and I have my electronic drums plugged into line 10. I can hear the drums with my headphones with ‘PAFL’ on but nothing through the speakers. I see green bar go up but nothing out of speakers. My firmware is 1.95. Thanks!!
If you PFL the LR output do you you hear anything?
Is it just channel 10 or other channels as well?
Check that ch.10 is assigned to the LR mix.
Do you have audio from ch.10 on any of the mix outputs?
Check that ch.10 is not assigned to a DCA group or groups and the
DCA master is turned down.
Did you buy it new or used?
Maybe try a hard reset.
Hello @Mattuati,
As the output sockets of the QU range are fixed to an output bus, please make sure you are connecting your speakers to the L&R output sockets.
Alternatively, as Mike C has advised, PAFL the Main Mix instead of the individual drums channel to make sure that the signal is in fact going to the Main Mix.
As a side note, the latest firmware available is V1.97, it is always good to stay up to date with firmware versions; so kindly update.
If you encounter any further issues, please submit a ticket at our support centre and I will gladly troubleshoot it with you:support@allen-heath.com
Thank you,
Rafael
Im going to get a usb stick so I can update to latest firmware
Curious on the suggestion of l and r output sockets. On the back of Qu Pac, should I plug into the ‘mains’ or the one that says ‘l amp’ which looks different than xLr or mix outputs r and l? Thanks!
Hello @mattuati,
The “Lamp” socket is used to connect a gooseneck light-lamp.
Please connect your speakers system to the Main L&R sockets.
Kindly have a look at your user guide (Pages 13 & 14) for more details regarding the different connections: https://www.allen-heath.com/media/Qu-Mixer-Reference-Guide-AP9372_10.pdf
Thank you,
Rafael
Hello,
I bought Allen & Heath CQ-20B in February 2024, In December 2024 I had a 3 hours event,
Issue was: in the event, sound fully stopped 3 time for a minute, each time I see application also disconnected from my tablet. I had to re-connect each time it stopped responding.
Does anyone know why it happened? is it shutting down by it self, what was the reason?
Kochee Kan
Bad power maybe ?
Or a power supply issue ?
Can you reproduce the problem ?
Does the CQ let you monitor the internal temperature ? (somewhere in the utilities menu). How high is it ?
Are you sure no one else is running the app also ?
Giga
Oh, btw: your series of mixers has it’s own forum ?
