First post
Just got my Q16 and couldn’t be more psyched!
I’ve read the manual, but can’t this one out:
My synths occupy most of the channels, my loop station, which serves both as a recording and playback device, occupies two. How do I route all synths to one out bus that feeds into the loop station in such a way that I don’t hear the active synth twice (once through its channel, once through the looper). A mix group won’t solve that. What does?
Thanks so much!
send them to the looper with a stereo mix
return the looper on stereo input (or two monos, as you like it)
if you have the sythies post fader then you have to bring up the faders for them and if you don#t want to hear them throug the master without the looper then you have to unroute them from the master
press the assign button and turn of the selects
I guess it’s not the way you could do everything you want but it gives you a starting point to feed the looper and to make the looper hearable without hearing the synthies twice
