Number of iPads?
Hi Folks
Can’t find a definite answer from the manual (though I may have missed it), and don’t have enough iPads available to check for myself right now.
Is the limit 2 iPads connected, or 2 Qu-Pad Apps connected at the same time?
i.e. Could I use 2 iPads with Qu-Pad running & a third with Qu-Contol.
I figure somebody must have tried this and know the answer.
Many thanks.
I am not certain about ipads, (as I use android,) but I found this on the QU-Pad overview page…
“The Qu mixer supports a maximum of 8 iOS device connections, including up to two iPads running Qu-Pad, with the other devices running the Qu-You Personal Monitor app or Qu-Control Customisable App for Install which are also available free from the App Store.”
https://www.allen-heath.com/ahproducts/qu-pad/
I also found this on the QU-Control overview page…
“Qu mixers support simultaneous connection of 7 iOS devices running Qu-Control or Qu-You, plus an iPad running Qu-Pad.”
https://www.allen-heath.com/ahproducts/qu-control/
Overall, I understand them to mean 8 devices total. If 2 devices are running QU-Pad, then the remaining 6 devices can be running either QU-Control or QU-You.
(Confusing)
Hi Mark,
Maximum of 2 iPads connected to the QU but 7 devices in total.
Lee
Yep, I’d found those, but thanks for looking. My reading of he second one makes me think it will work, but I’d love to hear from somebody who’s done it.
I often have 2 iPads running Qu-Pad + my iPhone doing Qu-Control. I’m considering replacing my phone in this setup with another iPad, as I’ve been offered one at a good price, and I’d prefer to keep my phone as a phone connected to the internet - how else can I send rude texts to the lighting guy!
I just need to know if it will work.
QuPad Help still states 8 (ethernet) connections in total, no matter if the pads are running iOS, Android or whatsoever, including up to two concurrent QuPads.
Previous versions only support a single QuPad connection and, if I remember correctly, one “other”.
Lee - have you tried it, or is that just your reading of the second of Gordon’s quotes?
Gordon’s second quote also states 8 connections in total. 7x QuControl/QuYou plus 1 QuPad. :wink:
Mark,
Only ever had 2 iPads running at once. Maybe someone on here who has access to 3 iPads could find out?
I believe that the only way to exceed 8 (which contains up to two QuPad) is to use the single available MIDI/TCP connection as per Mixing Station.
There is a hard limit of 2 QuPad - don’t know that QuControl has any such additional limit.
I have had three iPads connected - 2 running QuPad, and one running QuYou.
The connection doesn’t care what device is used…
“I have had three iPads connected – 2 running QuPad, and one running QuYou.
The connection doesn’t care what device is used…”
That’s what I wanted to hear! So two Qu-Pad & One Qu-Cotrol should work too.
Looks like I’m getting another iPad then.
Thanks Bob!
Mark, I have had 2 iPads using QUpad and a Samsung using mixing station all connected many times without any issues - if that helps.
I did quite a bit of experimenting with 3 iPads.
2 Running Qu-Pad and the other Qu-You.
It took a bit of sorting the Qu-You though.
I also managed thanks to Andreas to connect an iPad hard wired but still limited to using only 2 Qu-Pad altho the answer I would now think about getting an Android like debzdoodle.
If I was going to get another iPad I would buy iPad pro as you can use that for external monitors using Duet on both PC and Mac.
I’m just about to start a large project so had to rewire…
Here’s a few pics to see why I would buy the Pro…
