Offline AHM Connection problems
Continuing the discussion from Trouble connecting to Offline AHM32:
I’ve seen the thread above and one other with the same problem. Here’s the issue I’m experiencing:
  • I opened a connection to an Offline AHM-16 and built a config. As part of the config I set a password for the Admin profile.
  • When I tried to open the Offline AHM-16 again, I got the same error message: ‘Unable to connect to Offline AHM-32 (Invalid user name or password)’
  • Per the linked thread, I’ve tried uninstalling and reinstalling AHM System Manager multiple times with no change.
At this point I’m unable to login to the Offline AHM-16.
What’s the best course forward? Thanks!
Hi there!
Are you running System Manager on Windows or MacOS?
If you’re on Windows, delete the folder
C:\Users\<your username>\AllenHeath\AHM V1.61\PersistentData\Unit16\UserProfiles
It will be recreated when you open the offline AHM again.
If you’ve got the same issue on an AHM32 or 64, simply change the Unitxx number to match.
If you’re on Mac, you’ll find this in your user account’s Library folder -
Macintosh HD\Users\<your username>\Library\Application Support\AllenAndHeath\AllenHeath\AHM V1.61\PersistentData\Unit16\UserProfiles
We’ve got a bug logged in our system for this (you shouldn’t be able to set a password for an Offline AHM) and will fix it in a future software release.
Thanks @MarkF, appreciate it!
