A couple of weeks ago, I spent considerable time doing some offline programming. When I uploaded the show to the MixRack, some things – especially scenes – did not appear to upload.
This week, I fired up the MixRack with that same show still loaded in memory, and the Mixer Configuration seemed to have reset to an earlier version of my showfile. An Aux which I had added and used in the previous week’s shows was no longer present.
I’m hoping it’s just pilot error – but has anyone else seen symptoms similar to these? Thank you
Running iLive Editor 1.83 against an iDR-32 1.83.
Hi Timtrace,
After you have completed your offline session, are you re-archiving the show each time you make changes? If not your shows will not capture the latest changes you have made.
Hope this helps,
Steve
quote:
Originally posted by timtrace
…Most definitely saving…
To be a 100% sure. Updating the scenes and then archiving the entire show again?
Never had any issue with this, only when changing the mixer configuration I saw problems, but otherwise never.
Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
quote:
Originally posted by woutertTo be a 100% sure. Updating the scenes and then archiving the entire show again?
Yup. Odd, huh. I'm going to try to get it to do it again in the shop.
