One mic on two faders with different settings?
Hello everybody,
is it possible to have one microphone on two different strips without using a mic splitter and two inputs on the idr?
id like to have one “normal” strip and one with different eq settings so i can change between the two ones if needed.
Jan
Yep. No problem at all.
PS just assign the same physical input to two processing channels.
Wouter
IDR32, R72, Dante, Mixpad
laptop, TP-Link TL-WR1043ND</font id=“size1”></font id=“navy”>
Yes of course - you just have to select in the “preamp” section the same IDR Input. But be aware - the gain is the same for the two channels. If you need to have different gains you have to change it via digital “trim”
Albin
quote:
Originally posted by albinBut be aware - the gain is the same for the two channels.Albin
I tried it yesterday, the gain is a separate one…
Thanks for your help! Its working fine and i dont need a third hand on the desk!
Greets
Jan
Hmm, how can that be - its the same mic-preamp - so you cannot have two separate gains…
Its not possibility… maybe he thinks Trim?
