OneMix support
Hi folks. Have just started using the OneMix app on several iPads for band members to control their own monitor mixes on a GLD80. They are using a couple of apps and when you switch to another app and then switch back to OneMix you always have to reconnect to the GLD and login again. Is their a setting I can change so that it doesn’t log out each time you momentarily leave the OneMix app??
Apple drops the connection when an app goes in the background, unless the app makes noise. Nothing to be done about it.
Hm, is anybody using the Mixing Statio GLD Pro on Android device? I see it looks almost the same as the X32 app from the same developer, the Onemix is a bit cumbersome to use…
I’m a big fan of Mixing Station. The GLD version isn’t quite as full featured as some of his others, but basically it’s the same. You can change the layout however you want. He’s just gotten the RTA working in the EQs. He hasn’t figured out how to get to the GLD scene library, but if you’re replacing OneMix, you don’t want your musicians doing that anyway.
