OneMix
Hi All,
question regarding OneMix. Everything works fine.
I’ve setup OneMix for the drummer with channel strips kick, snare and bass.
Now he has EQ the bassguitar a litte bit.
I’ve setup a second iPad with OneMix for the bassplayer. he has in-ear system.
We added kick, snare and also the bass. When he’s EQ-ing the bass, this will affect also the EQ settings of the drummers mix.
How can i setup seperate EQ for all instruments per AUX?
regards,
Maarten Louer
Hi all,
Just figuring out howto do some EQ over monitors. It seems that i only can EQ things on the Aux bus, but not on channels. Lets say i have a stereo in ear mix, and the singer wants the guitar to be EQ’d how can i do that? FOH EQ is no problem but EQuing instruments over Aux channels. kind regards,
Maarten Louer
If you still have empty channels left, just doublicate instruments that need to be eq’ed differently. Naming will be important in order to keep things together.
KICK - for mains
DR.KICK- kick channel for drummer
BA.KICK- kick channel for bassist
VX.GTR- guitar for the vocalist, etc…
IDR32
Motion Computing LE1700
MBP/Logic Pro9
idontPad1&3
M-Dante
M-Waves.
Hi Letmefix,
thanx for you’re response. I have already setup channels 1 to 16 and 17 to 32
(with shared preamps from channels 1 to 16) gain knobs are blue
Is it possible then to share the preamp three times then?
regards,
Maarten
quote:
KICK - for mains
IDR32
MBP/Logic Pro9
idontPad1&3
M-Dante
M-Waves.
Hi all,
Maarten Louer
Yes, you can have one input for all 64 channels if you like.
ddff
