Alex, select a channel then hit the Routing key. On the screen you’ll see a Global Direct Out setting. Change this to where you want to tap the channel signal to send through the usb to your DAW. Note this setting affects all channels.
Thanks a lot, I really appreciate it. Basically I want to use the mixer sends and returns to use my favorite hardware to master my audio tracks,Let’s see if I can connect them… thanks again…
Keep one thing in mind when your looking at outboard input output patching options.
FX units like reverbs and delays are normally patched in parallel to the channels you want to apply the FX to. Taking a mix/aux out to the FX and bringing the FX output back
into the board on an open channel, Exactly like it was done for years on analog mixers.
Dynamic processor units, comps, gates and EQ are normally patched in series with a channel or channels using the channel insert or to process multiple channels by assigning multiple channels to a group and inserting the processor on that group, unfortunately the QU-16 does not have groups, that would make it a little easier to do this.
It sounds like in your case you want to insert your comp and EQ on the entire output mix of the board and be able to record it at the board.
To do that take the main L R outputs into your comp and EQ chain, take that output into one of the stereo input channels, on that stereo input unassign it from the main L R mix out and for that matter all of the mixes except 9-10, bring up mix 9-10 on the stereo channel to unity, assign it as post fade, then you will use the mix 9-10 outputs
to feed the system.
If you want to assign you comp and EQ to a channel or channels you would need to use a mix out to feed the comp EQ, bring up that mix on the channels your the comp and EQ on, set that mix to unity on the channel or channels, set the mix to past fade, un assign those channels from the main L R mix, take you selected mix output to the input of your comp EQ chain, take that output into a stereo input only in this case you will want to have that stereo input assigned to the main L R mix and to be safe un assign that stereo input from the mix that is feeding the comp and EQ.
OK I see that you got it to work while I was typing!
