I’m using an outboard processor (VoiceLive2 harmony generator) on a direct out.
I’d prefer this NOT to be an insert, as I’d like to record the unprocessed voice input (via Dante).
How do I get the direct out to be post fader? Should I assign it to a mono-group or an aux?
Rob
Rob
The Direct Output selection follows its global setting
configured in the MIXRACK SETUP / Mixer Pref / Direct Output
page. As an FX source this would typically be set to Follow Fader
and Follow Mute.
Ray
Hi Ray,
Ok. I’ve got “Follow fader, Follow mute” set up and everything seems to work fine. The FX unit’s giving me some nasty mids, but I can eq that out!
You mentioned “FX Source”. Can I explicitly mark it as “FX”? At the moment it’s just a direct out from IP1, and a stereo channel in on IP7/8.
Rob
Rob
and Follow Mute.
Ray
Hi Ray,
Rob
You can name this as you want, although it’s an external FX, the Ilive knows only that it’s source is taken at this particular direct out…I was quoting from the manual whereby if you use this direct out as an FX it should be logically setup as follow fader and follow mute …
Ray
