output routing with cubase elements and qu32
Hello,
I am using a qu 32 on a windows 10 laptop with Cubase elements 8.5. I have installed the qu 32 asio wdm driver from Allen and Heath.
I am able to record, however I don’t seem to understand the output routing? In VST connections, when I go to the output side, it is using the QU Asio driver and it says the left channel is routed to channel 1 and the right channel is routed to channel 2. It appears I can set it to any channel from 1 -32. However when I use 1/2 I move the sliders up and no sound is coming through the headphones nor is any signal being received.
I must apologize for my ignorance if this is a simple issue, I am getting quite frustrated. Any help would be appreciated!!
