Output Routing
The ability to route Outputs just like the Inputs.
Could you elaborate? Seems like you asking for groups (ie, make four different group mix A-B-C-D, then mix the group into OUTS).
A completion to the Mix Bus system.
When you are in the SENDS screen you can select Outputs and choose routing just like the Inputs.
Example:
Input 1 - Sends = Output 1 (Not Mains)
Output 1- Sends - Output 1 + Mains
Also apologies if this is covered
do not see an advanced search to only search this section and google didnt help.
I have an SQ/GX/DX as well, so I get the desire for flexibility (especially for a distant box), but couldn’t you just move the output cables?
Yes but that takes up an Input.
But that is the way I have to currently do it.
