PAFL - IEM to PHONES
Hi there, I’m not able to find the switch for PAFL IEM to PHONES as depicted on the block diagram. Can someone point me in the right direction?
Andy
Hi Andy, as per the attached pic, choose your PAFL bus (IEM), select MIX & you’ll see the option to turn individual Aux’s on and off in that PAFL (likewise, associate your wedge sends only with the Wedge PAFL bus & when you assign outputs it’ll only go to one or the other).
Thanks for the reply, that helps clarify that function. However, I’m still not sure how to switch the IEM PAFL bus (on fader) to the surface phones output, as the block diagram would suggest you can.
If you’ve assigned an AUX to the PAFL buss, selecting that Aux should send that output to the surface phones output AND any associated rack or surface outputs you’ve assigned (this is from memory of the last time I used it, but don’t quote me!)
