PAFL output to any mix bus
I would really love the option to output the PAFL to any physical output for use with studio monitors. I’m sure there are many others looking for this same thing.
Yes!
is it planned?
PAFL to a physical output is planned - confirmed by A&H in YouTube comments under the video about PAFL.
Routing PAFL to one of the mixes would be super awesome as this would help creating near field monitoring feed with PAFL and communication channels on one set of speakers.
Confirmed A&H Team just implemented this feature in Firmware 1.2 See the Release Notes.
V1.2.0
Additional Features:
D-Classic Automatic Mic Mixing added. Support for DX-Hub.
‘Chorus’ and ‘Noo Phaser’ FX units added. Assignable Channel Colours.
Factory Processing Libraries added.
Input to PAFL source point selection added.
Release-Notes-SQ-V1.2.0.pdf (367 KB)
That’s not the output port though. That is the ability to change pre-HPF or post delay or anywhere in between on the input channel strip.
Please confirm. Is it going to happen. Control room PFL IS REQUIRED
No, there is no possibility to route PAFL signals to outputs. It is only accessible via the Headphone output.
pafl to output port is absolutly requied for monitor operations.
The seperated wedge/IEM bus (featured in Dlive/GLD) would be a perfect addon for the SQ series.
+1 for ability to patch PAFL to physical xlr/trs outputs
Realy need this on working with a control room on live setup !
Please !
+1
If QU has this (and a ton of different pre/post PAFL pick off points), then I absolutely think SQ will get this.
Why it wasn’t implemented to begin with is beyond me.
+1 this is a must
I tried to use the SQ5 as a compact monitor desk last weekend with 7 G3 stereo IEMs, 2 wedges, and 2 side fills. I had to route my cue IEMs through the headphone port, which was noisy and unusable. C’mon A&H. This is supposed to be a pseudo-pro desk. Let’s get some PAFL routing to the balanced outs.
+1
I am a +1 for doing some improvement in PAFL/monitoring.
In the A&H grand overview of the console there is an entire section talking about how this is the perfect board for doing your IEMs and how you never need to gamble with the house monitor console again. But using an SQ board for a monitor console will not even be a viable option until the PAFL bus can be routed to an output other than phones jack AND put monitor/cue level control to a fader not the phones knob.
This is the biggest problem keeping me from wanting to switch over to a couple of full FOH/monitor SQ setups.
