PAFL output to any mix bus
+1000000
It is IMPOSSIBLE to mix monitors properly without a functioning cue wedge (a headphone jack is NOT acceptable).
There MUST be a ‘Cue to Master Fader’ mode as well.
This is advertised as “the ultimate IEM mixer” yet your monitor engineer can’t even cue a mix over his belt pack currently…
+1
This is now possible in firmware v1.3
Haven’t tried it, but you can see it in the patch screen.
With version 1.3, how to adjust the sound level of the PAFL circuit on the physical monitor output ?
I also did not find a solution for the PAFL output. But you can use the Listen bus together with the listen bus mode of the Main fader. On the listen bus you hear the same as on the PAFL but its level can be controlled.
I would love to have dedicated faders for PAFL and listen bus which are assignable to fader layers as well as on soft rotaries.
