PAFL Wedge causing echo in Aux mix channel
I have had this issue through a few versions of firmware. I have nothing routed to the wedge but, as long as it is unmuted a slap back type echo happens to my stereo Aux 2 mix which just happens to be my drum monitor mix :S. I have been through all of the routing and I can’t see anything that would cause this but, it might be something I haven’t considered so I thought I would ask to see if someone has any ideas of how this is happening before I bother support.
112T/IDR48/IDR16
Hi Kent
Where have you got your talkback feed assigned to? could this be the issue?
You could also try recalling a factory show to see if this fixes the issue?
Regards
Sam A&H
