Pan in scene
Is it possible to save only data for pan in a scene?
The ‘pan’ data is part of the “sends and routing” process when you save your scene, but is part of the ‘image’ tab under the scene safes page.
If your input channel ‘image’ is scene safe, your pan setting will not recall, but also take note of any aux output routing changes that you may or may not change as it will also be stored in your scene.
Is there a way to set only my aux sends scene save? If I understand you right, the result is only recal pan from that scene.
Yes, your aux routing can be set scene safe if you want it to be.
