I’m looking into getting a QuPac to use primarily without a DAW. Could someone please confirm if the following workflow is possible/easy to accomplish:
Connect instrument to line-input-1 and record to Qu-Drive track-1.
Disconnect instrument from line-input-1.
Patch playback of track-1 from Qu-Drive to channel-2.
Apply compression, effects etc to channel-2 and record to Qu-Drive track-2.
In short I want to know if I can build up a mix piecemeal, utilising pre-recorded tracks from the Qu-Drive, that can be further effected/re-fined without the original instruments being connected to the mixer.
Unfortunately, the record and playback mode of the Qu-Drive applies to all 18 tracks at once, so this would still require both modes to operate at the same time and that is unfortunately not supported.
It is possible for this to be done with a DAW, as the DAW handles the recording and playback differently to the Qu-Drive.
If you would like to go through this in more detail, please start a ticket at support.allen-heath.com
