Can we have a patch enable/disable switch like on the SQ. I cant tell you how many times I have accidentally changed the I/o while trying to scroll through it.
This is already a present in dLive. With the the I/O page active, press and hold the Setup key, then tap the center of the page where it says IO Patching Options. There you will find an option, Only allow patch when the “Patch” button is pressed. There is also an option, Confirm when reassigning, which can help avoid accidents too.
