pdf form idr-10 input list
well check it out
might be useful on festivals and so on
feel free to modify
https://megapeng.com/public/STAGEPATCH I-LIVE.pdf
suggestions welcome
cheers
dave
allen&heath i-live digital /focusrite octopre/ rme digi/multiface/
samplitude pro v 10.01 / sample-tank / synthogy ivory / DFHS drummer
algoritmix renovator/de scratch pro/de noise pro/peq orange red and blue /K-stereo
make shure you copy the whole line not only the underlined stuff
cheers
dave
MADE IT SMALLER HERE IT IS
cheers
dave
made a new one , the numbering is different
they correspond to the input channels (1 to 48)
cheers
dave
hm the mail thing does not work properly if one has only acro reader
cool would be too if it would spit out a txt file with the list
but my xml knowledge is too limited…if allen or heath had the time
to fix it (i bet they have xml nerds) i could send the source
cheers
dave
I think it is just me, but I can only save a blank copy. I had the thoughts of making one in Microsoft Excel and having drop down menu’s as you have done also. This would allow one to save different set-ups to refer back to them for making small changes without starting all over and then save again with a new show/event name. I guess I typed all of this to ask, if I had another version of Acrobat, would I be able to save it with the selections I made?[?]
yes you need a newer version, it is stupid with acrobat-if you have the pro version, you cant “prewiew” how it would be for a “a reader only user”
i found out home on a different machine (where pro is not installed).
did you try to do it online or did you download it?
if it is definetely not possible to store it like this i maybe should make a “basic” version with drums-bass gtrs- keys set waddayathink
plus there should be no drum names left after channel 16 (B8) to avoid “scroll through” annoyances.
cheers
dave
It is most likely that I only have the reader then. I did download the newest version of reader and I can only save a blank copy, not one with socket names. Even after I saved it to hard drive and input names, I still can’t save it with those. You may already have found this but,I did notice that on your newest version, socket A-3 has the number of ‘12’ instead of ‘3’ with the input names. Not to pick it apart, just to let you know.
i know about the numbering-did it on purpose- to have both the slot numbers AND the input channel numbers, but it looks like is has to be done with flash hmm…anyway it has been promised in the next editor update ,
for me as i have acrobat pro it helps me through the festival season as a workaround we are thinking anyway of having a computer screen next to idr 10 on stage to avoid printing…this way you just update the sheet without saving
thanks for your input(i ll check with my flash nerd if he can help me that could even be more interesting coz there you can make a script wich imports txt files…so the customers/bands just bring a txt file)
cheers
dave
