Peak Lights
Hi
Been using the T112 since beginning of the year after switching from SD8 i prefer the way the gain structure seems to work on the ilive but find i do get peak lights at times are they set early as i dont hear any distortion ?
Dave
Hi Dave,
Input channel metering is post-processing, pre-fader, but the red Peak indicator is multipoint sensing which means it keeps a check on signal activity throughout the channel path. It lights to warn that the signal is within 5dB of clipping. If it lights before the rest of the meter this means that the signal is peaking earlier in the channel path.
Please also note that iLive meters are fast response digital absolute peak meters. This ensures you keep control and avoid digital clipping of signals including those with very fast dynamics. It does mean the iLive meters may read hotter than those on other consoles you are used to. It is perfectly ok to work with meters reading well into the yellow.
Hope this helps
Nicola
A&H
Thanks for the info Nicola
Dave
Good inside info Nicola.
R72 & IDR32
MacBook pro
iPad 2
Airport express router
