Hello
I have an SQ-5 that I use in my home studio. I bought an SQ-5 Peak Limiter76 Compressor Limiter and would like to mount it on one of the 8 stereo FX engines. Any possibility of being able to do this in the next update?
Thanks for listening.
no, this makes absolutly no sense
I think the idee is to use the compressor before the peq, this make sense in studio use.
Richard
Maybe it would be helpful in such situations when you can change the procession order from Compressor after EQ to Compressor before the EQ. But I would also like to have all Channel Compressors in the FX Rack too. This would allow you to use two Compressors in one Channel. But then it would also be better to define the tap point of the insert more freely.
Look at the X32 or, even more flexible, the WING as a blue print. Even if I am missing on the WING the compressors in the FX Rack.
