Hello,
All your other board have peq and graphic on mains and mons. Please update so we can select peq and graphic and not use fbaq.
I beleive this is an absolute necessary and basic basic feature that could be easily tweaked.
I’ve just read that were maxed out at 4 peq +16 fba, so how about if we could at least manualy adjust the FBA frequencies when in fixed mode?? that would work!!
Besides that, what a great board!
On our CQ, I don’t use the FBA at all…nor do I use the PEQ on outputs, just the GEQ…
Hi
For me GEQ is typically “notchy.” I’ll use it to notch out problem frequencys/ room resonances etc. it works but it doesnt have the smooth flow of a peq which i’ll use to shape the overall kit to taste!
I’ll be using the fba with some fixed filters then hold and no live filters on main.
On monitors same except i’ll use the fba with fast recovery . (So it can notch out freqs on my mons live (which you can hear..)but it wont affect the FOH mix and keep us safe from un wanted feedback!
The thing you read was on the money - there are 20 filters available on each output channel on CQ. You’ll notice that this is where you get the 4 PEQ + 16 FBA or a 20-band GEQ.
So, you wouldn’t be able to have GEQ and PEQ as this would exceed the available resources.
Adjusting the frequency for the filters on the FBA is a good idea, though - something for us to consider.
Thanks Mark!
I hope that eventually comes through!
Happy day
