PFL LED fading at high levels
The product i’m using is discontinued so this may be the wrong forum but it’s a general question regarding PFL LED. The model i have is a Mix Wizard 3 16:2, when nearing the peak in pre-amp settings instead of the top light turning red the whole display seems to blink / fade. Is this likely to be a fault with the pre amps or simply a bulb in the LED in need of changing? I can still get a decent sound while there does seem to be slightly more prevalance in sibliance / distortion but only at high pre amp levels. Is this a known or common issue that is likely to be a hardware issue or simply the LED in need of changing?
Hi Steven,
Sorry to hear you are having trouble with this.
If this is still an issue, please submit a ticket at support@allen-heath.com and a member of the team that deals with discontinued products can help you with this.
Kindest Regards,
Nicole
