Firmware 1.6.1 When PFL pickpoint is set to after delay/AMM, any PEQ settings are not heard. If the pickpoint is stepped back to after compressor, then I can hear PEQ settings.
Is this fixed in 1.6.2?
A couple of questions - what are you not hearing it on? And do you mean you are not hearing the PEQ but the EQ is set and doing it’s job?
With a functioning channel, eq engaged and audible through groups or output, when listening in headphones to the PFLed channel, only the UN-EQed audio comes through the headphones.
It’s as if the PFL pick-point is pre eq, but it is actually post delay/AMM.
If I change it to post compressor, then the result of eq is audible.
