Phantom feature
Does the QU-32 Digital mixer have the phantom feature?
Not sure what you mean. If you mean phantom power for condenser mics then yes it does. On a per mic basis.
Yes,where is that in the mixer?
Obviously time to for me to place The Manual Link: Check Page 30, phantom power is engaged from the screen.
Press select on a channel. Press processing to right of screen. In upper left press on the gain knob area to get preamp page. On left side in 48v button. Press and hold a couple seconds to turn on 48v. Hope that helps.
Yes it does. You will find it on the touch screen after you select a channel. You will not see it if you have the main L/R selected. In order to engage it you must press and hold for about a second.
The A-H manual for engaging the phantom power is next to useless.
Where is the difficulty? It’s just a switch in the UI of the preamp, like nearly all other digital consoles on the market.
Nothing unusual here.
