I have question about phantom power on Qu (or any digital mixers). When you link 2 channels into 1 Stereo channels (for keyboards for example) and apply +48V for powering 2ch DI-box, is it applied to both channels or is it somehow different? Is it maybe dangerous for DI if applying +48V on both channels?
Another question: 2 days back, I used 8ch multicore with stagebox on stage and I had 8 condenser mic pluged in (so phantom power on each channel). As I touched stagebox/or cable/or just mic stand slightly signal was peaking on some channels (really audible pops). Multicore is one of the cheapest ones you can get, but that is what I was given - is it multicore fault, or I did something wrong? I solved it by unplugging 3 cables and putting them directly into Qu-16.
If you are using active DI boxes which are sourced by Phantom power, you’ll obviously need to apply Phantom power to each of these channels, same applies for a 2ch DI box, which normally should be just two isolated DI boxes in one case. When linking two channels on the Qu Phantom power is automatically applied to both of them.
Phantom power requires proper cabling, particularly the ground pin. If ground is not properly connected you’ll get exactly what you described (and may feel some prickle in your fingers as well).
Thanks! So it’s not true (as I heard) that it may cause damage to 2ch DI - but it’s not logical to me. Cables were mine, I never have problems when working with them and I use a lot of condensers sometimes. I really assume it was this really cheap multicore, or something, I don’t know. Thanks for help!
NOTE: DB2-A needs the phantom power from at least one channel, in any case we suggest to send the
phantom power from both channels if connected: this ensure a second power safety option.
hey
if the problem is not fixed, pls check out every kabel !
I had the same probleme if one of the multicore cable was damaged. i.e. short circuit between two lines (1<>2 oder 2<>3)
sometime it was a broken line
