Hi all,
I’ve got a very technical question, but it’s also real-world based so I thought some of you might have an answer to this…
We’re getting a Nexo rig in a few days, and I came across this tidbit in the manual.
I mix LR+S currently, and that seems like it could cause a problem…
quote:
PrecautionsIt is common to use the AUX send of a mixing desk to drive the Sub section of a PA system. This gives
the mixing engineer more flexibility to set the level of the subbass relative to the main PA, apply special
effects, or to use a different EQ on the Sub. However, it also raises some serious issues for the
performance & safety of the system (mostly time alignment).
At NEXO, great care is taken to design optimum phase alignment from one octave above to one octave
below the crossover frequency point. By doing so, drivers are working perfectly together and providing
the best efficiency possible. It is then up to the user to adjust the delay on the NX TDControllers to
match the physical path difference of the different systems. It is thus possible to get a well adjusted
system, even without measuring instruments.
If RS15s are driven form an AUX output, NX TDController is fed with two signals coming from different
sources. If those two sources (MAIN output & AUX send) are not exactly in phase, delay is introduced
into the crossover between GEO S12 array and RS15s.
</font id=“quote”></blockquote id=“quote”>They suggest
quote:
Before using different outputs of a mixing desk, ensure that MAIN and SUB outputs arein phase;
- Never add additional low pass filtering on the SUB output or high pass filtering on the
MAIN output;
- Always apply identical processing (EQ etc…) on both outputs, so that the phase
relationship between MAIN and SUB is not altered;
</font id=“quote”></blockquote id=“quote”>So, it sounds like I should gang basically everything except level, routing and mute on the sub feed to the mains? I read something in the 1.9 release notes about… well ill just quote it below, should mean I’ll have no trouble?
quote:
Coherent Mix buses
Mix buses of the same type are now time coherent to avoid comb filter effects when combined, for example when mixing Groups together
</font id=“quote”></blockquote id=“quote”>iDR-48, T-112, Mixpad
College
