I´v got PL-6 remote for iDR-32. Tap tempo is not what I´m tapping. In editor tempo is fine.
Kalle
Kalle Nettan
IDR-32/PC/BCF2000
Kalle
Kalle Nettan
IDR-32/PC/BCF2000
did you auto assign led to button?
cheers
dave
allen&heath iLive-144 /idr 10 / idr 48 /dante (i want midi in dante!)
yes,I did. does it interrupt with tempo? I´l trie without it.
Kalle Nettan
IDR-32/PC/BCF2000/PL-6/iPad2
nono it shoud be displaiyng correcetly, although i am not satified with any tapping - even with standalone t.c. delays
cheers
dave
no change, display on-off, still tempo something 100 ms faster than I tap
Kalle Nettan
Just a guess but perhaps the PL6 measures the tap time interval from button release to button on so it might depend how long you hold the button down when tapping. Perhaps someone might be able to verify this as I don’t have a PL6 to test this theory?
Cheers
Richard Howey
Audio Dynamite Ltd
thank you for the hint, but unlikely so, will try this also tomorow
Kalle Nettan
Hi All
We are aware there is some latency with LED flashing when assigned to tap tempo on a PL device, this is not a problem with audio, only the latency of the flashing LED so you are still be able to tap a correct BPM for the delay using the PL buttons when assigned to tap tempo.
To improve the PL tap tempo latency with reference to the tap tempo on the surface softkeys you could connect your PL device to the PL port on a modular surface if you have this option available.
Regards
Sam A&H
aha that is why i did not notice it (144 here)
cheers
dave
Regards
Sam A&H
still tempo is much faster than I tap it
Kalle Nettan
