Pop's when changing scene - Help needed asap
I have a bit of a problem. I’m going on tour tomorrow with a gld 112. The show has 24 scenes, and the problem is that whenever I change scene, pops appear in the monitors AND FOH. The only way I have found to avoid it, is to SAFE the master and the 6 aux’es for monitors, and then mute them when changing scene, and then unmute them when I have done the scene change. BUT that is offcourse and issue for the show, because there will be dropouts in the sound from the show. And I have plenty of other, more important things to do during the show, than to mute 7 chanel’s before changing scenes.
I have notices that the pops are bigger, if the scene I change to, has a lot of effects going. But it’s a show with a lot of hall verbs, so I cant avoid that.
Any ideas as to how I can avoid this?
Help is much appreciated
I can’t help with the pops, but if you have an extra DCA available make a mute group for all you ‘parts’. Might help.
Any chance the scenes are changing the state of phantom on an open channel?
Same idea here. Check phantom power status on each input per scene. Are there any ghost channels open but not draged to the surface?
It wasn’t a phantom power issue. But I found the solution in changing the crossfade time to 0,4 seconds.
Thanks for the help guys…
