is it possible to record a multitrack not on an SD card, but on a USB, because this function does not work for me, only SD, I bought an SSD when I had a QU-SB, everything worked there, I can write to USB only MAIN
See pages 58 and 131:
Best Regards,
Tobias
correct me if I’m wrong what I found is multitrack recording either via USB B or to the SD card via USB A will not work correctly?
You can either record multitrack to SD card or via USB B direct to your Mac or PC.
You can only record two track to the USB A.
So unless you can find an adaptor or something where you can plug in your SSD, I am not sure what else I can suggest.
This would be a helpful feature. Currently I have to wait half an hour plus to transfer files from sd to my computer before I can do anything. It would be great to have the multitracks recorded direct onto a USB stick so they can be used direct from there. Should be technically possible as the USB interface will be faster than SD card transfer speeds.
